Colinleung
May 24, 2024Follower
R6220 access control with error message
When I enable the access control, Error message: Action=start can't find this application? id=3141906dcd255761 HTTP/1.1 404 Not Found Server: DATE: Fri, 24 May 2024 06:46:21 GMT
michaelkenward
May 24, 2024Guru - Experienced User
This is with a web browser and the graphical user interface (GUI)?
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
