abuser32
Apr 29, 2016Aspirant
R6220 and HP Photosmart 6250 connection problems
I just upgraded my router to the R6220 AC1200. Loving it and it seemed to be working perfectly until tonight when I realized I cannot print. The printer appears to be connected, printing out a wirele...
- May 04, 2016
abuser32
Okay so somehow I got the IP address on the printer to work and now I can print from my computer! So that's a good sign, but still can't print from any device. The printer still fails to show up. Any ideas now?
- DexterJBMay 04, 2016NETGEAR Moderator
Hi abuser32,
You will need an AirPrint compatible printer for you to print from your iOS devices. You can read about it using the link below.
https://support.apple.com/en-us/HT201311
However, you may use the ReadySHARE Print feature of your router as a way for you to print from your iOS devices. This will require you to connect the printer to the USB port on the router instead of the Ethernet port. You may check the link below for reference.
http://kb.netgear.com/app/answers/detail/a_id/20913
Dexter
Community Team
