LMillsap
Dec 15, 2021Follower
R6220 bridge devices between LAN, 2.4G and 5G
I have a printer and laptop that only "know" about 2.4G wifi. We have several iOS devices that we like to use on the 5G wifi. The problem is, when an iOS device is on the 5G wifi, it cannot see the p...
Dec 15, 2021Guru - Experienced User
You should contact your printer manufacturer to see what they'd recommend.
It shouldn't matter if you're on lan/2.4g/5g.
