jmoulton1
Dec 27, 2022Aspirant
R6220 Bridge mode
How do I set my Netgear AC1200 router model R6220 to bridge mode? I need to do this in order to get rid of my double NAT for gaming console reasons.
- Jan 06, 2023
Unfortunately, the pix mean nothing to me.
Did the link I sent earlier mean anything?
How to bridge mode DZS router | DZS Router Bridge mode H660EW-V - YouTube
You can narrow down the options by looking fir the things on the modem. Does it have a row of Ethernet ports on the back? Does it do wifi?
On the gem, is there a user community out there somewhere? Its equivalent of this place.
michaelkenward
Dec 30, 2022Guru - Experienced User
jmoulton1 wrote:
I only have one router and one modem.
What is that modem? Make and model? Does it have a row of Ethernet (LAN) ports 9n the back?
The troubleshooting platforms I have come across say it is probably due to double NAT.
That is why I asked about the modem. If it is also a router (many are) that can cause double NAT.
I tried to fix the issue on my router by going to routerlogin.net and was not given the option to put it into bridge mode in advanced settings.
It may be the modem/router that needs to be in bridge mode. (There is no "bridge mode" option for the router) Do that and you put it into "modem only" mode. That disables the router but and eliminates the double NAT problem.
jmoulton1
Dec 31, 2022Aspirant
Here is a picture of the bottom of my modem. The brand is DZS (the one provided to us by our ISP at the time of installation).
If I were to change the setting to modem only then would that affect the WIFi connection on other devices coming from the Netgear router? The yellow cord is plugged into the Netgear router. I am not able to send a picture of that. It only allows me to send one attachment at a time. I do have a picture though if you want to see it. Thanks!
- michaelkenwardDec 31, 2022Guru - Experienced User
That looks suspiciously like a modem/router. (Does it also do voice, phone, connectisns?) That is likely to cause the NAT problem you see.
If I were to change the setting to modem only then would that affect the WIFi connection on other devices coming from the Netgear router?It shouldn't. If anything it should clean up your network and get the modem out of the way.
The challenge could be to put this thing into bridge (modem only) mode. You'll have to track down a model number, or ask your ISP, for help on that front.
- jmoulton1Jan 04, 2023Aspirant
The modem possibly could have a phone, voicemail, etc. however, we do not have a landline so it is not set up for that. I did contact my ISP about the issue and they suggested using a public IP address to solve the issue. I'm worried that this would cause security issues with the WIFi. If I were to go this route, is there a setting in the Netgear router that would solve this issue or is there a way to change the setting to Modem only in the router?
- michaelkenwardJan 04, 2023Guru - Experienced User
It may not be set up for voice, but that does not mean that the router bit is disabled. The good news is that you don't have to accommodate any voice features.
I did contact my ISP about the issue and they suggested using a public IP address to solve the issue.I don't know what they mean by that. which IP address?If it is the "Internet IP Address" most ISPs use the option Get Dynamically from ISP.
I'm worried that this would cause security issues with the WIFi. If I were to go this route, is there a setting in the Netgear router that would solve this issue or is there a way to change the setting to Modem only in the router?I can't see how messing around with the Internet IP address would affect the wifi, but I don't know what they mean by that.
What you really want to know is how to put your modem/router into "modem only" mode. Unfortunately, without knowing the model number, you can't run the usual Google search for bridge mode. (That is one somewhat confusing label for modem only mode.)
This is the best I can manage:
I have no idea if it applies to your model.
As I said before,
"Another scenario is to put the R6220 into wireless access point (AP) mode, disabling its router bit."
