USA-mum
Apr 21, 2017Follower
R6220 cannot connect to Wii ....
- Aug 23, 2017
Hi carter91014,
It may not be a router issue since you have other devices that are able to connect without problems.
You can check the link below found on Nintendo's forum. You can contact Nintendo support for this as well.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52130&system=Wii
Dexter
Community Team
DexterJB
Apr 25, 2017NETGEAR Moderator
Hi USA-mum,
1. Please add more details regarding your setup.
2. Is the Wii connected to the router via wired or wireless?
3. If via wireless, are you connecting to the right WiFi and using the correct password?
4. Are your other devices working fine?
Dexter
Community Team
carter91014
Aug 20, 2017Aspirant
Hello, I have a Netgear R6220. I am trying to connect wirelessly to a Wii. I have tried numerous things and can't get it to work. I have many other things connected but I have two Wii's not connecting to it. Both give the error (52130)
- DexterJBAug 23, 2017NETGEAR Moderator
Hi carter91014,
Dexter
Community Team
- DexterJBAug 28, 2017NETGEAR Moderator
Hi carter91014,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
