ChurchIT's avatar
ChurchIT
R6220 DHCP Relay support?
BLUF: Can the R6220 wifi router support DHCP relay for multiple subnets, or do I need to replace it with a switch that has this functionality? Background: I'm the head of IT for a non-profit (read...
  • plemans's avatar
    Oct 04, 2022
    The R6220 is a pretty base model device. it doesn't have the more advanced features that you're trying to achieve.
    You'd be better off to check on the business equipment to achieve that. The consumer side is lacking the vlan segregation/multiple subnets.
