ChurchIT
Oct 03, 2022Aspirant
R6220 DHCP Relay support?
BLUF: Can the R6220 wifi router support DHCP relay for multiple subnets, or do I need to replace it with a switch that has this functionality? Background: I'm the head of IT for a non-profit (read...
- Oct 04, 2022
The R6220 is a pretty base model device. it doesn't have the more advanced features that you're trying to achieve.
You'd be better off to check on the business equipment to achieve that. The consumer side is lacking the vlan segregation/multiple subnets.
Oct 04, 2022Guru - Experienced User
ChurchIT
Oct 04, 2022Aspirant
That’s what I was suspecting, but I appreciate the confirmation!
