Robbert14
Dec 13, 2020Follower
R6220 Failed firmware update. no wireless networks and no connection via ethernet
Hello there, Today I tried updating the firmware of my router via the nighthawk app, whilst simultaniously streaming to my chromecast. The app said that the update went well and then the router ...
gte558w
Dec 13, 2020Aspirant
Same issue, after doing the firmware update 1.1.0.104, the router boots up and get stuck in USB LED on only with no other LED. I tried resetting it both with 7-sec and 30-30-30 method but nothing worked. I tried to flash the old firmware 1.1.0.100 and also the new one with TFTP method. The files transfer is successful but same end result with only USB LED keeps on after reboot.
Not sure what happened with this new firmware update.
GeorgeBarkley
Dec 22, 2020Aspirant
Had the same problem. Can't connect to the router after firmware update, either wired or wireless. No DHCP when hooking it to an ethernet cable to computer. No wireless lights on but LAN lights on. Power light is off. Tried Factory reset but it doesn't change anything.
