LaManLee
Apr 17, 2018Aspirant
R6220 firmware update
I get the message from GUI of login page that a new firmware is available for upgrade. It states that the latest version is V1.1.0.64. But the download is stopped in the midway. I check the websit of...
- Apr 18, 2018
There is support for the R6220 somewhere at the end of this link:
>>> R6220 | Product | Support | NETGEAR <<<
Firmware Version 1.1.0.66 is the latest. If you have it, you are up to date.
antinode
Apr 17, 2018Guru
> [...] Is it safe to upgrade the firmware using the download one from
> support website?
Unless the firmware kit says that it's only for some other region, it
should be ok. Just follow the instructions in the Release Notes.
