rusmms
Jul 31, 2017Aspirant
R6220 game lag (SoF2 DH)
R6220 firmware: V1.1.0.50_1.0.1 Everything works except one thing - the game (Soldiers of Fortune 2 DH) hangs after 3-4 minutes online playin. While if instead of R6220 I connect the old router (Zy...
- Aug 01, 2017
Hi rusmms,
1. Please make sure you have done a factory reset after updating the routers firmware.
2. Please make sure you have forwarded the necessary ports for the game if there are any. You can check with the game developer/forums for more info.
3. Does the issue persist on all devices where the game is installed?
4. Does the issue persist on other games?
5. Does the issue persist on both wired and wireless connections?
Dexter
Community Team
rusmms
UPD: with previous firmware V1.1.0.34_1.0.1 problem was the same.
- DexterJBAug 01, 2017NETGEAR Moderator
Hi rusmms,
Dexter
Community Team
- rusmmsAug 02, 2017Aspirant
TY!
Still yesterday I looked with a sniffer at network exchange and I noted that since a certain moment packets from the server do not pass through a router. I decided that it is necessary to try to forward ports. And today I read your message.As a result ports are forwarded, everything works.
Thanks for assistance!
