rusmms's avatar
rusmms
R6220 game lag (SoF2 DH)
R6220 firmware: V1.1.0.50_1.0.1 Everything works except one thing - the game (Soldiers of Fortune 2 DH) hangs after 3-4 minutes online playin. While if instead of R6220 I connect the old router (Zy...
  • DexterJB's avatar
    DexterJB
    Aug 01, 2017
    Hi rusmms,
    1. Please make sure you have done a factory reset after updating the routers firmware.
    2. Please make sure you have forwarded the necessary ports for the game if there are any. You can check with the game developer/forums for more info.
    3. Does the issue persist on all devices where the game is installed?
    4. Does the issue persist on other games?
    5. Does the issue persist on both wired and wireless connections?
    Dexter
    Community Team
