Delaynomore's avatar
Delaynomore
r6220 I can't change wifi tranfer out put control to super wifi
It used to be have a option to control the output power in Advanced MENU before upgrade the fireware.
  • DexterJB's avatar
    DexterJB
    Oct 12, 2015
    Hi Delaynomore,
    All firmware versions (1.0.0.14, 1.0.0.16, 1.0.0.17, and 1.1.0.31) of the R6220 do not provide the option to modify the transmit power for the wireless signal. Did you own a different NETGEAR router before?
    Dexter
    Community Team
