Delaynomore
Oct 03, 2015Aspirant
r6220 I can't change wifi tranfer out put control to super wifi
It used to be have a option to control the output power in Advanced MENU before upgrade the fireware.
- Oct 12, 2015
Hi Delaynomore,
All firmware versions (1.0.0.14, 1.0.0.16, 1.0.0.17, and 1.1.0.31) of the R6220 do not provide the option to modify the transmit power for the wireless signal. Did you own a different NETGEAR router before?
Dexter
Community Team
DexterJB
Oct 05, 2015NETGEAR Moderator
Hi Delaynomore,
1. Are you referring to the wireless output power?
2. What is the current firmware version of the device?
3. What firmware version were you using before?
4. Please provide a screen shot of the setting if possible.
Dexter
Community Team
Delaynomore
Oct 11, 2015Aspirant
I don't recall the version
- DexterJBOct 12, 2015NETGEAR Moderator
Hi Delaynomore,
Dexter
Community Team
