kchumps
Jan 31, 2020Star
R6220 Internet LED not working
As of maybe two hours ago, I can no longer connect to my router. I still have a connection if I plug my pc into the modem, but that's a PITA. Any suggestions? Resetting does nothing. I tried that tip ...
- Jan 31, 2020
What are all the lights on the router doing?
What modem are you using?
did it randomly stop or what were you doing when it disconnected?
Can you hardwire into the router to access the gui?
Have you tried a factory reset? Push and hold reset while its powered on for 7-15 seconds. The lights should change.
kchumps
Jan 31, 2020Star
I'm surprised it works if it's that old. I'll definitely do that, but in the meantime I am connected again, thanks to you. Maybe this was one of the bugs?
Jan 31, 2020Guru - Experienced User
The release notes go over all the bugs and security fixes. I know one of the more recent had a bug fix for wan/lan throughput but they don't go into specifics usually.
