bobsch7050
Mar 31, 2022Aspirant
R6220 Is there a means to disable the 2.4GHz transmission s while still using the 5GHz functions?
I would like to disable the 2.4GHz transmissions while still using 5GHz because the 2.4GHz interferes with other electronics near my router. What I have been doing is pushing the WiFi on/off button o...
wcalifas
Mar 31, 2022Prodigy
You gotta log into your routers settings and go to the wireless section and it will show both bands being on, you have to click off "broadcast SSID" when you're logged into it.
bobsch7050
Apr 08, 2022Aspirant
Tried it. Works great!
