cearlp
Jan 26, 2020Tutor
R6220 LAN setup
Does the R6220 support ip reservation? If so, when you reserve a particular ip address for a particular device shouldn't that device show that ip adress in it's configuration? for example: I reserv...
- Jan 26, 2020
try rebooting the pc and router at the same time. The router isn't immediately going to switch the device over when you reserve the IP address.
