teletek
Jun 10, 2017Aspirant
R6220 loses connection after 30min
Hi guys, I recently made the switch from my old & trusty Asus RT-N15U to a R6220. I ran the interface and was instantly connected. But for some reason that I can't figure out, every 30 min I lose...
- Jun 14, 2017
Hi teletek,
You can try changing the MTU value. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
teletek
Jun 11, 2017Aspirant
I tried not running the router as a DHCP and the only difference it made was that my iOS devices didn't get an IP. Still drops the connection after 30 minutes from restart on the dot.
- DexterJBJun 14, 2017NETGEAR Moderator
Hi teletek,
Dexter
Community Team
- DexterJBJun 19, 2017NETGEAR Moderator
Hi teletek,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- BjarnJul 06, 2017Aspirant
Hi DexterJB
I'm experiencing the exact same problem with my R6220. Every 30 minutes the Internet connection drops and I need to reboot the router to get it working again.
I've tried your tip regarding changing the MTU but according to the ping results there was no need to change the defaul value (1500).
Any suggestions what to do next?
