vkulit
Oct 19, 2018Initiate
R6220 New firmware V1.1.0.80 issue
I'm just reporting a problem with the latest firmware release for this router. I use my router to work from home. Ever since the firmware update, my calls disconnect every 5 minutes on the dot. I look...
- Oct 24, 2018I've done that multiple times with no success. But I found a fix for the problem.
Download and install the old firmware, I did this 2 days ago and everything is working perfect.
DexterJB
Oct 24, 2018NETGEAR Moderator
Hi vkulit and Hampurilias,
Please make sure that a factory reset is done after the firmware update.
Dexter
Community Team
Hampurilias
Oct 24, 2018Tutor
- vkulitOct 27, 2018InitiateResetting the router to default was the first thing I did. I downloaded the previous firmware and everything is working as it should. Thank you!
