Jazmatron
Jun 19, 2020Follower
R6220 only showing USB LED light, not even the Power light is on
We just got a new internet service and are trying to connect to our R6220 router. It seemed to be working at first and we were prompted to do a firmware update. The update ended (we are unaware if it ...
RVALENZ
Jul 21, 2020NETGEAR Employee Retired
Welcome to NETGEAR Community!
You can try to reset the device for 30 seconds if it helps. These light represent that it might be defective already.
Try connecting a computer and check what the IP address connected to a LAN port.
Rhys
NETGEAR Community
anand230999
Dec 14, 2020Tutor
I'm also facing the same issue the router is not pingable so I can't try the tftp method. I have tried nmrpflash with older as well as newer firmwares but after rebooting the usb light and the respective ethernet LED will glow.
- VijayMIBDec 26, 2020AspirantHi Anand please share the steps of performinh nmpr flash
- anand230999Dec 26, 2020TutorAll details are here. Just follow these procedures.
https://github.com/jclehner/nmrpflash- VijayMIBDec 26, 2020AspirantThank you Anand. NMRP flash also didn't worked because router is not getting ON. It only shows USB led ON only. I have not attached any device to USB port.
