Jazmatron
Jun 19, 2020Follower
R6220 only showing USB LED light, not even the Power light is on
We just got a new internet service and are trying to connect to our R6220 router. It seemed to be working at first and we were prompted to do a firmware update. The update ended (we are unaware if it ...
Alexhongkong
Dec 23, 2020Aspirant
Me too~ i failed to update firmware 1.1.0.104. And only USB light is on after reboot. I also tried to use tftp and nmrpflash to fix but fail too.
I can find few similar cases from Internet. I think that may be a problem of that firmware 1.1.0.104.
anand230999
Dec 23, 2020Tutor
Does anybody knows to fix this using serial port?
