jacoc
Oct 04, 2021Aspirant
R6220 poor wifi cover
Hi. I have the R6220 router. On the box the cover is 110m2 but i have extremely poor coverage in my room that is 5m away. How do I go about fixing this error?
Oct 04, 2021Guru - Experienced User
A little more details help.
1. what are your interior walls made of? Certain materials block wifi better than other.
2. what actual speeds are you getting? Over wired? Over 2.4ghz? Over 5gh?
3. what firmware is on the router?
4. what modem/gateway is it connected to?
Details are key.
jacoc
Hi,
I have normal brick and plaster walls.
My firmware is 1.1.0.110.
2.4ghz - 18 up and 10 down
Fibre cable connects to router directly.
