jacoc
Oct 04, 2021Aspirant
R6220 poor wifi cover
Hi. I have the R6220 router. On the box the cover is 110m2 but i have extremely poor coverage in my room that is 5m away. How do I go about fixing this error?
jacoc
Hi,
I have normal brick and plaster walls.
My firmware is 1.1.0.110.
2.4ghz - 18 up and 10 down
Fibre cable connects to router directly.
Oct 05, 2021Guru - Experienced User
jacoc wrote:
Hi,
I have normal brick and plaster walls. ----brick and plaster walls block wifi very well.
2.4ghz - 18 up and 10 down-----what do you pay for for speeds? what speeds do you get over 5ghz? 2.4ghz is a slow network.
Fibre cable connects to router directly. ---what ONT do you have?
