mnbvc
Dec 06, 2022Tutor
R6220 randomly drops LAN connections
I've been using a R6220 wifi router for the past five years and just recently it started giving me trouble. At random times, all LAN connections to the router will drop for about five seconds before ...
- Dec 08, 2022
The router has been running a full 24 hours and there have been no drops in the LAN connections. I think this problem is fixed.
Whether or not it was caused by the firmware update is not certain, but it seems the solution really was as simple as a factory reset. Thank you, Plemans, for your assistance.
Dec 07, 2022Guru - Experienced User
What modem is the router connected to?
If you noticed it happened after a firmware upgrade, I'd try the factory reset and reinstall.
Sometimes firmware changes enough that a reset can help.
Does wifi drop as well?
- mnbvcDec 07, 2022Tutor
Thank you for replying. The modem is a Fios ONT device supplied by Verizon (I think a Nokia 211). The wifi is not affected by the problem, or at least I have not noticed it ever happen.
I can try a factory reset later, but what do you mean by a "reinstall"?
I'm including a screenshot of the router statistics. It looks like the last drop happened 21 minutes ago, but the wifi has stayed active.
- plemansDec 07, 2022Guru - Experienced User
Just that while you're reinstalling, don't use a backup. If somethings corrupt in the settings a backup can carry that over.
Okay, got it. I will try that tonight.
In the meantime, I found something interesting. When I check 'ipconfig /all' on my Windows PC I get the following:
Lease Obtained. . . . . . . . . . : Wednesday, December 7, 2022 11:14:17 AM
Lease Expires . . . . . . . . . . : Thursday, December 8, 2022 11:14:16 AMThat's normal. But in the router's connection status I see this:
When the "Lease Expires" time gets down to halfway is exactly when the drop occurs.
I will try the factory reset tonight and report what happens the next day.
