mnbvc
Dec 06, 2022Tutor
R6220 randomly drops LAN connections
I've been using a R6220 wifi router for the past five years and just recently it started giving me trouble. At random times, all LAN connections to the router will drop for about five seconds before ...
- Dec 08, 2022
The router has been running a full 24 hours and there have been no drops in the LAN connections. I think this problem is fixed.
Whether or not it was caused by the firmware update is not certain, but it seems the solution really was as simple as a factory reset. Thank you, Plemans, for your assistance.
mnbvc
Dec 07, 2022Tutor
Okay, got it. I will try that tonight.
In the meantime, I found something interesting. When I check 'ipconfig /all' on my Windows PC I get the following:
Lease Obtained. . . . . . . . . . : Wednesday, December 7, 2022 11:14:17 AM
Lease Expires . . . . . . . . . . : Thursday, December 8, 2022 11:14:16 AM
That's normal. But in the router's connection status I see this:
When the "Lease Expires" time gets down to halfway is exactly when the drop occurs.
I will try the factory reset tonight and report what happens the next day.
mnbvc
Dec 08, 2022Tutor
I factory reset the router last night and manually changed the settings. So far so good. The router statistics shows the LAN connections have been up for about 11 hours and counting. There doesn't seem to have been any drops since then, but I want to do some more testing before I declare the problem fixed.
- plemansDec 08, 2022Guru - Experienced User
Hope it stays solid!
- mnbvcDec 08, 2022Tutor
