mnbvc
Dec 06, 2022Tutor
R6220 randomly drops LAN connections
I've been using a R6220 wifi router for the past five years and just recently it started giving me trouble. At random times, all LAN connections to the router will drop for about five seconds before ...
- Dec 08, 2022
The router has been running a full 24 hours and there have been no drops in the LAN connections. I think this problem is fixed.
Whether or not it was caused by the firmware update is not certain, but it seems the solution really was as simple as a factory reset. Thank you, Plemans, for your assistance.
Dec 08, 2022Guru - Experienced User
Hope it stays solid!
mnbvc
Dec 08, 2022Tutor
