Rgba8's avatar
Rgba8
R6220: ReadyShare does not work
I have R6220, firmware V1.0.0.17_1.0.1. I have 4000 videos on my WD EasyStore 4GB external hard drive, NTFS formatted. I have connected it to my R6220 and enabled Media Server. When I try to access it from my Roku TV, I see only one folder instead of dozens. When I try to get into the folder, it tells me that there are no supported files there. My files are mp4. If I connect the hard drive to the TV directly, it plays all the files without any problems. Is there a way to fix this? If not, what other router would let me do it?
1 Reply
  • I have tried to put files on USB Flash drive - 32 GB and it did not work too. I have also tried to put all files in the root of the USB flash drive to avoid folders, but I still can't see them.
