DarrenCG
Jan 28, 2020Tutor
R6220 Router - Cannot See WD MYCLOUD Network Drive
I have recently swapped over to an R6220 Router. All works fine except I cannot see my WD Mycloud Network Drive. The drive was visible and worked fine on my old Router. All the LED's on the WD Dri...
- Jan 28, 2020
Try putting the netgear in AP mode. You'll lose its routing function and have to rely on the sagecom for router but will still be able to use its wireless and ethernet ports. But it'll put all your devices on the same subnet.
DarrenCG
Jan 28, 2020Tutor
I think you may be on to something here, but seems the Modem/Router from the ISP, which I have now identified as a Sagemcom 2704n, doesn't have any option to change to Bridge mode.
I'll be moving in about 4 weeks and changing to an ISP that uses fixed wireless Technology (rather than ADSL), so the issue should hopefully be resolved then as I'll just use the Netgear Router, but is there anyway round this in the meantime.
Jan 28, 2020Guru - Experienced User
