Efelch98908
Dec 23, 2017Aspirant
R6220 router-Epson Printer and IPhone show offline
R6220 and Epson XP-630 connection issues. My Epson XP-630 is connected via wireless. The Netgenie software show the printer on line for a short period of time then the Status shows offline. I am u...
- Dec 28, 2017I spoke to level 2 tech support. We attempted to reset the router as you had said. According to the tech and the responses the router gave us, there is something wrong with the hardware in the router. I will be exchanging it.
DexterJB
Dec 26, 2017NETGEAR Moderator
Hi Efelch98908,
If the printer is connecting via wireless, then you do not need the NETGEAR Genie software/app. Just make sure that the printer drivers are properly installed on the computer you want to print from. Also, please make sure that the printer is among the attached devices on the router. You can do that by accessing the router UI via a browser then going to Advanced > Administration > Attached Devices.
Dexter
Community Team
Efelch98908
Dec 26, 2017Aspirant
The things you indicate are correct. The other issue is the devices connected to the 2G wireless network cannot communicate with the devices on the 5G wireless network.
- antinodeDec 26, 2017Guru
> [...] devices connected to the 2G wireless network cannot communicate
Both wireless networks used are normal, not guest, networks?- Efelch98908Dec 27, 2017AspirantCorrect. Discovered something else. I had my laptop connected to a wired LAN port to work with tech support. Attempted to print. Nothing happened and got a message stating "Printer offline". Print happened when I disconnected from the LAN port and reconnected on the 2GHz wireless network, same as the printer.
- antinodeDec 27, 2017Guru
> [...] Print happened when I disconnected from the LAN port and
Obviously (I'd say), unless a guest network is involved, all the
devices on the LAN, wired or wireless, should be able to communicate
with each other. (All the IP addresses show the same subnet, I assume.)
If that's not working as expected, then the router's settings may be
scrambled, and it may be time to employ the panacea: full ("factory")
reset and (manual) reconfiguration. In principle, you could save the
settings before, and restore them after, the reset, but if the settings
are scrambled, then restoring saved (scrambled) settings might simply
restore the bad behavior. (You could get lucky, of course.)
