Efelch98908
Dec 23, 2017Aspirant
R6220 router-Epson Printer and IPhone show offline
R6220 and Epson XP-630 connection issues. My Epson XP-630 is connected via wireless. The Netgenie software show the printer on line for a short period of time then the Status shows offline. I am u...
- Dec 28, 2017I spoke to level 2 tech support. We attempted to reset the router as you had said. According to the tech and the responses the router gave us, there is something wrong with the hardware in the router. I will be exchanging it.
antinode
Dec 26, 2017Guru
> [...] devices connected to the 2G wireless network cannot communicate
> with the devices on the 5G wireless network.
Both wireless networks used are normal, not guest, networks?
Efelch98908
Dec 27, 2017Aspirant
Correct. Discovered something else. I had my laptop connected to a wired LAN port to work with tech support. Attempted to print. Nothing happened and got a message stating "Printer offline". Print happened when I disconnected from the LAN port and reconnected on the 2GHz wireless network, same as the printer.
