Aristillus
Feb 05, 2018Follower
R6220 Router might be bricked. Need help
I was doing a firmware update when my power trip. When i try to connect to the gateway ip to do the firmware update, it doesn't load and there is no internet connectivity. The router 1 and 2 is blinki...
- Feb 06, 2018
Hi Aristillus,
1. Have you tried going through the TFTP process linked below?
http://kb.netgear.com/app/answers/detail/a_id/22688
2. If yes, at what step do encounter an issue?
Dexter
Community Team
DexterJB
Feb 06, 2018NETGEAR Moderator
Hi Aristillus,
Dexter
Community Team
DexterJB
Feb 11, 2018NETGEAR Moderator
Hi Aristillus,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
