Razen
Mar 20, 2021Aspirant
R6220 set in "Access Point Mode", slower download speeds ?
Hello, So I recently got myself a router (the Netgear R6220) in my room because the router provided by my ISP is too far from my computer, so we passed cables in the walls, and everything was wor...
- Mar 20, 2021
> Because then I have a Wi-Fi hotspot in my room, [...]
Ok. I know nothing, but my first hypothesis (guess) is that the
(non-deluxe) R6220 is too slow if you use its WAN/Internet port for the
connection to the main router. If that is the problem, then I see two
possibilities:1. Use a gigabit/s-capable network switch for the speed-critical
wired devices, and connect the R6220-as-WAP to that switch for your
(less speed-critical) wireless needs.2. Try using a different WAP configuration scheme for the R6220,
which does not use its WAN/Internet port. See, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. If the router which you're reconfiguring has a WAN/Internet
Ethernet port (unlike a Cxxxx), then leave it unconnected.You might see some odd (but minor?) problems that way, like, say, the
Internet LED might not look right, or the R6220 can't find a time
server, so its date+time might be wrong. I'd run the experiment, and
see if the wired speed improves, and then see if there are any
significant problems. It should be educational, at least.
antinode
Mar 20, 2021Guru
> [...] I recently got myself a router (the Netgear R6220) in my room
> passed cables in the walls, [...]
If you're connecting everything using Ethernet cables, then why buy a
router (and configure it as a wireless access point)? Why not spend
less, and get a (simple, cheap, Gb/s) network switch?
