Caprican
Jun 24, 2022Aspirant
R6220 slow download speed when enable "Access Point mode"
Hi, The wireless download speed seems to be limited to 100 Mbps when changing from Router Mode to AP mode. With router mode, download speed is about 250 Mbps, but it will become 100 Mbps when ch...
Caprican
Hi plemans:
Thanks for your reply đ
I think I find the root cause. It seems the WAN port speed is down to 100 Mbps, when I enabled IPTV on LAN1 and link status in 100 Mbps on LAN 1.
After chaning to AP mode, I can't see the port statistics on WAN port but only find the counters and link speed on LAN ports.
(But I'm pretty sure the link speed of WAN port is 1 Gbps when using router mode.)
As you can see there is a device connecting on LAN1, with link speed 100 Mbps.
And the download speed is increased from 100 to 250 Mbps once I remove the cable from LAN1 or disable IPTV feature on LAN1.
I'm not sure if this is a expected behavior but looks weird to me.
Jun 24, 2022Guru - Experienced User
Have you tried a different cable?
