bassriverbro
Feb 14, 2019Aspirant
r6220 slow throughput
Running a r6220 with netgear cm400 modem. I am only getting 1 or less MBPS over wireless AND wired network. However, if i connect directly to the modem I'm getting advertised speed of >100 MPBS.
the issue is definately the modem. This seems to have started recently. Firmware Version
V1.1.0.86_1.0.1.
upload speed is consistent wired through modem, or router.
qos is off as well as any traffic meter.
Any ideas here? Its been rebooted, reset, 30-30-30.
Seems to be fixed now. maybe it was a fluke test intitially, but found slow speeds even when connected directly to modem. resetting modem with the paperclip didn't work, or i did not do it correctly. resetting the modem to factory defaults through the admin login did, i'm back to 50+ mbps download.
1 Reply
- bassriverbroAspirant
