TeamT
Jan 17, 2017Star
R6220 stop to respond to DNS queries.
Hi, My R6220 router with firmware V1.1.0.34_1.0.1 stops to respond to DNS queries aproximately every 4th day. Restart of the router fix the problem temporarily. I have saved WireShark captures to...
- Nov 11, 2017
Hi,
My router has been OK for 27 days now. There are good reasons to assume that the bug has been fixed.
Kind regards,
TeamT
TeamT
Jun 02, 2017Star
Seth21 just curious on how you "renew the DNS" to make the router work again. I have ony been able to find two ways to clear out the DNS fault.
- Restart of the router
- Reconnect / Connect the WAN cable (saw in the dubug log that the Domain Name Relay Deamon restarts when you disconnect / connect the WAN cable)
/ TeamT
Seth21
Jun 02, 2017Guide
Login to router at 192.168.1.1; go to advanced - then connection status and click 'renew'. It is nice because you can do it from your desktop as my router is downstairs and my office upstairs.
I'm about ready to send this router out to pasture and just move on.
- TeamTJun 09, 2017Star
Router failed again. New logfile uploaded to Netgear. Same symptom again. When socket number reach 1023 DNS stop to respond.
- Seth21Jun 09, 2017Guide
Oh nice diagnostics. I will be honest, mine was failing every 2-3 days so I have another router connected and my new 'great' router is sitting next to it unplugged.
Hopefully we can find a resolution so I can start using it again or atleast fix it enough to be able to sell it to someone.
