TeamT
Jan 17, 2017Star
R6220 stop to respond to DNS queries.
Hi, My R6220 router with firmware V1.1.0.34_1.0.1 stops to respond to DNS queries aproximately every 4th day. Restart of the router fix the problem temporarily. I have saved WireShark captures to...
- Nov 11, 2017
Hi,
My router has been OK for 27 days now. There are good reasons to assume that the bug has been fixed.
Kind regards,
TeamT
vhovar
Oct 25, 2017Initiate
I have had my R6220 for almost a year now with no issues. I was looking through the configuration last week when I added an IP Camera and enabled DynDNS. It seems that after I did that and added the camera I started having this exact problem. I've turned DynDNS off but now continue to have the problem with the DNS not responding until I reset the router. This happens every night and has started happening during the day. I'm thinking about trying do do a factory reset and reload the current firmware to see if this might help resolve the issue.
PatriciaMcC
Nov 15, 2017Aspirant
Exact same here. Worked for a year, then started failing after adding an IP camera (Armcrest). I didn't enable DynDNS at any time. I have to reset the router every morning. Now it has failed in middle of the day. I might try static IP on camera and maybe even point its DNS elsewhere.
