anthonystubb
Mar 21, 2017Aspirant
R6220 Stuck in USB
When I power on the device, the Power led goes green for about 5 seconds, goes off and then the USB led stays lit even though nothing is plugged in. I have found that if I hold the Reset button whil...
- Mar 21, 2017
Here is the link for reflashing the router https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
William10a
Mar 21, 2017Master
Sounds like the router is not booting up and may be bad frimware or possible hardware would go the frimware as my best bet.
Have you reset the router by chance?
