anthonystubb
Mar 21, 2017Aspirant
R6220 Stuck in USB
When I power on the device, the Power led goes green for about 5 seconds, goes off and then the USB led stays lit even though nothing is plugged in. I have found that if I hold the Reset button whil...
- Mar 21, 2017
Here is the link for reflashing the router https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
William10a
Mar 21, 2017Master
Sounds like the router is not booting up and may be bad frimware or possible hardware would go the frimware as my best bet.
Have you reset the router by chance?
anthonystubb
Since no wifi is being brodcast, I cannot update the firmware through any means that I'm aware of.
Yes, I have tried to reset the router using multiple methods including the Reset button and Power button.
- William10aMar 21, 2017Master
Do you have a laptop or desk top computer with a wired lan port you could connect a lan cable between the router on a free lan port the the lan on the computer to access the router if the lan ports are working.
- anthonystubbMar 21, 2017Aspirant
Yes I do. The router is currently hooked to my laptop via an ethernet cable to the Lan 1 port on the router.
If the lan ports are working you will have to have to use tffp program to reflash the router will find the link to it and post for you you will need a fresh copy of the firmware to reflash on to the router.
