anthonystubb
Mar 21, 2017Aspirant
R6220 Stuck in USB
When I power on the device, the Power led goes green for about 5 seconds, goes off and then the USB led stays lit even though nothing is plugged in. I have found that if I hold the Reset button whil...
- Mar 21, 2017
Here is the link for reflashing the router https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
William10a
Mar 21, 2017Master
If the lan ports are working you will have to have to use tffp program to reflash the router will find the link to it and post for you you will need a fresh copy of the firmware to reflash on to the router.
William10a
Mar 21, 2017Master
