anthonystubb
Mar 21, 2017Aspirant
R6220 Stuck in USB
When I power on the device, the Power led goes green for about 5 seconds, goes off and then the USB led stays lit even though nothing is plugged in. I have found that if I hold the Reset button whil...
- Mar 21, 2017
Here is the link for reflashing the router https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
anthonystubb
Fantastic, that actually worked. Thank you =]
