rardark
Dec 28, 2023Aspirant
R6220 Supports Site-to-Site VPN?
Hi Everyone, May I ask if I can use the OpenVpn function in R6220 (together with a asus router) to setup site-to-site Vpn? Thanks!
- Dec 28, 2023
"This article applies to":
It appears this model router doesn't support that feature:
https://kb.netgear.com/24267/NETGEAR-Routers-and-UTMs-that-support-VPN
rardark
Dec 30, 2023Aspirant
I would like to setup a site-to-site vpn using R6220 with an Asus router. According to the manual from netgear, I can only use OpenVPN software in a computer to connect R6220 VPN service? Thanks!
michaelkenward
Dec 30, 2023Guru - Experienced User
You could start by finding a VPN that fills your needs and then investigating how to implement it on your network.
There are so many out there that it isn't possible to come up with definitive advice for a particular router.
