lordhades
Feb 03, 2019Aspirant
R6220 V1.1.0.86_1.0.1 firmware update?
Hi,
Got an update to firmware version V1.1.0.86_1.0.1 for the AC1200/R6220.
I cant find the firmware update notes anywhere but the internal router check found that update and applied it. ...
- Feb 04, 2019
This firmware is now on the support pages for this router:
Phesix
This is the same issue I had on my AC1750/R6350, it's possible the site and update server are just out of sync. I'm curious if your auto update/analytics appeared in the link ( http://routerlogin.net/tc_exist_unit_hijack.htm# )
lordhades
Yep. That link is the exact thing I got. I haven't enabled them because I wasn't sure if their update server had been hijacked or not since there is no official changelog for this firmware.
- PhesixFeb 03, 2019AspirantYeah, it seems like an odd name to give that link. I'm not sure what to think about it, but it could just be a hot fix like I was told, and the full version will be updated later.
- michaelkenwardFeb 04, 2019Guru - Experienced User
- lordhadesFeb 04, 2019Aspirant
Thats all I needed.
Thank you.
