lordhades
Feb 03, 2019Aspirant
R6220 V1.1.0.86_1.0.1 firmware update?
Hi,
Got an update to firmware version V1.1.0.86_1.0.1 for the AC1200/R6220.
I cant find the firmware update notes anywhere but the internal router check found that update and applied it. ...
- Feb 04, 2019
This firmware is now on the support pages for this router:
lordhades
Yep. That link is the exact thing I got. I haven't enabled them because I wasn't sure if their update server had been hijacked or not since there is no official changelog for this firmware.
Phesix
Yeah, it seems like an odd name to give that link. I'm not sure what to think about it, but it could just be a hot fix like I was told, and the full version will be updated later.
- michaelkenwardFeb 04, 2019Guru - Experienced User
- lordhadesFeb 04, 2019Aspirant
Thats all I needed.
Thank you.
