Matosawitko
Nov 29, 2018Aspirant
R6220: WiFi and wired behave as two separate networks
Between Google searches and other posts on this forum I've seen others express similar issues, but no resolution as far as I can tell. So I'll try to explain exactly what I'm seeing, in the hope that...
- Dec 07, 2018
So I think the issue is finally resolved. I downloaded the latest firmware from the router's support page and reinstalled it. After the factory reset post-install, suddenly everything started communicating correctly.
Not sure why my previous resets didn't work, but at least my router actually routes now.
Matosawitko
Dec 07, 2018Aspirant
- antinodeDec 07, 2018Guru
> [...] I downloaded the latest firmware from the router's support page
> and reinstalled it. [...]
As always, an actual version number would be more useful than your
opinion of what's "the latest" today.- MatosawitkoDec 07, 2018Aspirant
Fair enough. As stated in the OP, I was previously running 1.1.0.80_1.0.1, which is also the version that I downloaded and reinstalled.
