mbgoldberg's avatar
mbgoldberg
R6220 Wifi Router ERR_SSL_KEY_USAGE_INCOMPATIBLE when try to access login screen from Chrome browser
Nighthawk R6220, FW version V1.1.0.114_1.0.1 Suddenly started getting  ERR_SSL_KEY_USAGE_INCOMPATIBLE  from Google Chrome browser running on Windows 10.   I can still log into router admin page fr...
  • mbgoldberg's avatar
    mbgoldberg
    Sep 24, 2024
    Sharing the solution I found.
    Trying to access the router's login page via browser started failing on Chrome browser.
    Bookmarked page was : www.routerlogin.net/index.htm
    Changed link to go to
    www.routerlogin.net
    (Omit the /index)
    And now I can access the router's login page.
    Sharing this in case anyone else runs into this issue.
