rjonesq
Apr 17, 2017Aspirant
R6220 wireless misbehaving
I have having no end of frustrations with my router. I should say that it was working perfectly for months, but suddenly these new problems have started arising. Here are my devices: * Netgear R...
DexterJB
Apr 19, 2017NETGEAR Moderator
Hi rjonesq,
1. What is the firmware version of the router?
2. Please make sure that the devices are not connected to the guest network if it is enabled.
3. Does the issue persist on your other wirelessly connected computers?
4. Have you tried resetting the router?
Dexter
Community Team
- rjonesqApr 23, 2017Aspirant
1. The firmware version is V1.1.0.34_1.0.1. The update tool says this is the most up to date verison.
2. The guest network is not enabled (it has *never* been enabled) and nothing is connected to it. However I do agree that the devices are *acting* like they are isolated on the guest network. I discovered that if I connect to the 5GHz network, I can see and connect to wired devices. However, if I connect to the 2.4GHz network, I have the problems described above. The reason my laptop could talk to my printer was that my printer can only connect to the 2.4GHz network. If I connect my laptop to the 5GHz network, I can connect to the router but not to the printer. If I connect my laptop to the 2.4GHz network, I can connect to the printer but not to the router or any other wired devices. I can connect to the *internet* with both options.
3. Yes, I am having the same issue with every wirelessly connected device. None of my laptops can connect to the Netgear Genie on the 2.4GHz network.
4. I tried resetting the router today. I saved my settings first then restored them after the reset. There has been no change in the behavior. I still cannot connect to the router if I am on the 2.4GHz connection, and I still cannot connect to my printer if I am on a wired connection or a 5GHz connection.
- DexterJBApr 23, 2017NETGEAR Moderator
Hi rjonesq,
Thank you for the update. Please try re-flashing the firmware then do factory reset and see if the issue will persist when using the default configuration (without restoring your config file).
Dexter
Community Team
- rjonesqApr 24, 2017Aspirant
That seems to have helped. Here are the steps I went through.
* I downloaded the latest firmware and re-flashed it.
* I verified that this did nothing to solve the problem.
* I did a factory reset using the reset button on the back of the router.
* I let the genie set up the internet connection
* I manually configured the wireless setup
* I did not apply *any* of my other previous settings
* It looks like everything is fully connected now. I tested that I can reach the printer *and* the Netgear Genie via ethernet, 2.4GHz, and 5GHz.
* The only thing I've notice is that Windows Homegroup computers can no longer see each other, but I assume that is a different problem to debug. As far as I can tell my connection problems have been resolved. I guess we'll never know what was causing the problem...hopefully it won't come back!
Thanks for the help!
- DexterJBApr 24, 2017NETGEAR Moderator
Hi rjonesq,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team
- golliday7Apr 30, 2017Aspirant
I have a AC1200 Smart WiFi router with External Antennas Model R6220. I wanna know how to hook up my printer and my roku to this. Sounds like a dumb question but i am having a problem getting this resolved. Need your help.
Thanks Dale
