rjonesq's avatar
rjonesq
R6220 wireless misbehaving
I have having no end of frustrations with my router. I should say that it was working perfectly for months, but suddenly these new problems have started arising.   Here are my devices: * Netgear R...
  • DexterJB's avatar
    DexterJB
    Apr 23, 2017
    Hi rjonesq,
    Thank you for the update. Please try re-flashing the firmware then do factory reset and see if the issue will persist when using the default configuration (without restoring your config file).
    Dexter
    Community Team
