tchw
Jun 17, 2017Aspirant
R6220 wrong system time
Under Security-> Schedule -> the year is 1970 Had set the time zone GMT+8 but seems the system time cannot be adjusted. Firmware: V1.1.0.42_1.0.1 Current Time: Friday, 2 Jan 1970 05:31:11 ...
- Jun 27, 2017
Hi tchw,
You can try the solution offered by FlyRbry on the thread linked below.
Dexter
Community Team
William10a
Jun 18, 2017Master
Sounds like the router is not connecting to the time server to tell the router the correct time and date.
If you ever go to use parent control under Genie the time and date will be a big issue.
- tchwJun 18, 2017Aspirant
I had never apply any parent control on the router.
May I know which time server is R6220 connecting?
