CT1958
Aug 09, 2022Aspirant
R6220
Good afternoon! I just have a simple question and I hope that I can solve this minor problem. My Nighthawk Router is working and online. The trouble I am having is that when I go in to look at my dev...
Aug 10, 2022Guru - Experienced User
What modem/gateway is the router connected to?
You mean that on your browser gui, the router is showing as not connected to the internet?
(screensnips are beneficial to helping understand things)
CT1958
Aug 16, 2022Aspirant
I thank everyone that replied to my problem. I do greatly appreciate it. After just calming myself down, and thinking everything through and going through all the menus and connections, I was able to figure out my problem and now my R6220 Router is showing that it’s connected when I go into the system settings/devices, it now shows that it’s connected and I have gone back to check every so often and it’s still showing connected, so now I don’t go checking any longer and everything is running much smoother and the speeds are where they should be. This is a great community. It’s wonderful that there are ones like yourself that takes the time to help. Blessings to you!
