bwhasty
Jan 20, 2023Follower
R6220
I have several Devices connected to this Router at my Office. The Router will not assign IP Addresses to all of my connected wired devices. The cables are good I've tested with my Laptop and the rout...
Jan 20, 2023Guru - Experienced User
What modem/gateway do you have the r6220 connected to?
If the office is on a different IP address from default, theres a decent chance its in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
