RomanP's avatar
RomanP
R6220
Hi, I have the latest firmware and I'm having trouble accessing Wi-Fi. Once setup is started, it cannot be disabled or disabled. Enable access control, when it turns out to be disabled, after changing and saving, the new configuration is not saved.
  • michaelkenward's avatar
    michaelkenward
    I'm having a hard time understanding your problem.
    Start at the beginning. Can you explain what you mean by "having trouble accessing Wi-Fi".
    The rest is also hard ro follow. What does this mean?
    What are you doing and where does it go wrong?
    What firmware version do you have on the device?
    A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
    I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • RomanP's avatar
      RomanP
      So once again: I have a router R6220 Firmware version: V1.1.0.114_1.0.1. As I enter the access control section, this device shows that this mode is disabled, but in the status and physically is enabled the former. Secondly, this mode can not be turned off or on again, after pressing Apply nothing changes the application does not respond. Thirdly, and most importantly, I can't set permissions for new wifi devices.
        michaelkenward
        Where is this "access control section". Are you referring to something on the Nighthawk app on your mobile device?
        Start by explaining what you are trying to do?
        Are you trying to manage how wifi devices connect to your router?
        Which "mode" is this?
        Where are you doing this? Where is this Apply button?
        Again, is this in an app? In the browser graphical user interface (GUI)?
        Where are you doing this?(See above.)
        What permissions are you trying to set?
        You did not tell us what modem you have. It might be important.
